    Timed the drop of the clamp, over a minute & also over an hour, etc on both machines (clamp dropped from 100.6 to 96.5 in period of 1 minute, mold fully closed in 46.5 minutes). 1.Replaced brake valve (issue still the same). 2.Checked oil level. Replaced oil and oil filter (issue still the same).3. Re- adjusted pressure on brake valve from 20 bar to 25 bar (no change, issue still the same). Any suggestions what could possibly be wrong?
    Lee Roberts's Avatar
    Lives in Milton Keynes, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,985. Received thanks 247 times, giving thanks to others 824 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hi Elvis and welcome to the forum,
    Sorry I can be of any help on this one, hopefully some others with more experience can give you some ideas or pointers...
  1. Replies: 25
    Last Post: 01-04-2022, 08:13 AM
  2. Herbert 2D 6 turret lathe with pegboard control and hydraulics
    By JaviPK7 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 07-01-2022, 11:58 AM
  3. Triac VMC Servo // Z-Axis Dropping on power off
    By danielbriggs in forum Machine Discussion
    Last Post: 09-07-2018, 10:35 PM
  4. Why does it happen when you are under pressure ?
    By cropwell in forum Milling Machines, Builds & Conversions
    Last Post: 23-12-2013, 11:12 PM
  5. Mold Making?
    By Shinobiwan in forum Moulding Machines
    Last Post: 27-02-2013, 02:15 AM
